I encourage you to read thru the several extensive threads on these inverters. My self, @1201 , @lapsmith and @BKY2003 and others have discussed various aspects of them here and uploaded/linked to a number of documents you should read.Hi I am in the market for a grid-tie inverter. I am looking at growatt min 11400tl-xh-us. I was wondering if anyone has experience with them and if it has UPS?
Agreed. Consider where you will install it and if you can abide by the 1 foot clearance requirement. Any inverter will get hot if installed in a hot environment. My MIN 11.4’s are in a unconditioned basement that never gets above 80 degrees even when 100 outside and never get hot. There are a lot of things to consider.It does get hot though. It's fanless and running flat out like that it will get to 185 degrees. I suggest if you are going to load it up to have a fan blowing at it. I use a fan and temps do not get above 130 now
I moved mine down to get the 1ft of clearance at the top and without the fan , when it's cranking out 11.4kw for hours it will still get above 180 while the shed is below 80 degrees.Agreed. Consider where you will install it and if you can abide by the 1 foot clearance requirement. Any inverter will get hot if installed in a hot environment. My MIN 11.4’s are in a unconditioned basement that never gets above 80 degrees even when 100 outside and never get hot. There are a lot of things to consider.
18.5 on one, 9 on the other, will be 15 soon. But we are off grid and not selling power. Our load never gets above 9 or so kW and in good sun will be charging at 10 or so kW early in dayI moved mine down to get the 1ft of clearance at the top and without the fan , when it's cranking out 11.4kw for hours it will still get above 180 while the shed is below 80 degrees.
How much pv do you have going into your inverters?
What do your temps max out at?18.5 on one, 9 on the other, will be 15 soon. But we are off grid and not selling power. Our load never gets above 9 or so kW and in good sun will be charging at 10 or so kW early in day
One thing people probably don’t consider, when you run your inverter flat out selling power it does consume lifetime. Time at temperature is a primary driver for degradation of most electrical equipment and equipment in general- something to consider when thinking about ROI.
SA screenshot for today, about 80 degrees outside. Doors open to basement so essentially same inside/outside temperature. I didn’t have solar assistant until recently. The spike in early morning on inverter 1 is when mini split came on in room wife homeschools youngest son in, on auto schedule.What do your temps max out at?
I'll vouch for that. I only got on 10kwh battery (LG) because it was half off from my local distributor. But it has been a nightmare (going on 2 or 3 months) trying to get them to work together. It is still not working. It shouldn't be so difficult because I'm told Sun Run uses that combination quite a bit.but the batteries for it are very very expensive,
