S Davis
- Sep 25, 2021
- 766
What is up with the opening for the D/C cables? It doesn’t line up with the terminals and is too small for 4/0, I had to cut the case. Also all the control connections are under the cables? Even if I had room on my buss bar for two 2/0 you can’t get two on the negative terminal with the way the cut out is.
