FilterGuy
Solar Engineering Consultant - EG4 and Consumers
NOTE: After learning more about the PowerPro battery and its capabilities, I have updated this and the follow-on posts for clarity and correctness.
There has been a bit of discussion on paralleling the EG4 PowerPro battery. This and the following posts show many of the most common configurations.
The PowerPro battery is in the process of getting UL-certified for putting 3 in parallel using the internal Busbars and supplied cables. EG4 has also started the process of getting UL Certification of 5 in parallel.
If there is a need to go beyond 5 batteries in parallel, there are several options.
For PowerPro batteries with a single EG4 18Kpv, here are several possible configurations using the internal busbars.
- If using multiple EG4 18Kpv inverters, Each inverter can have a separate bank of up to 5 Batteries.
- Multiple banks of up to 5 batteries can be linked together in parallel with a fused balancing link (Max 200A fuse)
- External busbars can be used to parallel multiple batteries, just like any other battery.
