Q-Dog
¯\_(ツ)_/¯
Ran my fridge 2 weeks through a KillAWatt and the usage number I got was nearly identical to the energy guide estimate. Samsung with bottom freezer and digital controls. Freezer runs at 0ºF and the fridge section at 36º.
New EU energy ratings dropped A++ fridges to C or D rating.
I have been keeping eye on efficient fridges and now actually saw first EU2021 A-rated model.
Haier H 3 R 330 WNA 190.5 cm x 59.5 cm weiß Kühlschränke Kühlschränke ab 85cm
Haier H 3 R 330 WNA 190.5 cm x 59.5 cm weiß Kühlschränke Kühlschränke ab 85cmwww.wermuth.de
330 litre fridge with only 66kWh per year. Or 180Wh per day. Or average 7.5 watts!
What are they measuring differently? How are their measurements different and how much of that is driven by some company paying them money?
Energy efficiency isn't just about money saved in operational energy costs.
It helps to extend the functionality of a given energy supply system (you can do more with less), and/or reduce the scale of the energy supply system needed in the first place (less up front investment required to supply your energy needs).
That's my attitude as well. Panels are so darn cheap its not worth replacing my refrigerator.. Why spend $3000 on a fridge when I can spend $400 on panels?The energy supply can be calculated in $$$, whether from PV, LiFePO4, or gasoline. It makes a convenient "currency" for consideration of efficiency options.
For products and services we buy, the cost gives some indication of labor and energy input, including for shipping.
So I would compare the purchase price of a replacement refrigerator with purchase price of additional PV panels to power the old, inefficient one.
This is how I came to the decisions of over-panel/under-battery, and don't replace my old reliable energy-hog refrigerators. ("Reliability" is harder to put a price on.) I just need to set up a (night time on battery) disconnect for the refrigerators, due to how small my battery is compared to nighttime loads.
That would be my approach as well and I can’t care less how much electricity our home fridge currently uses as we heat the house with electricity anyways.The energy supply can be calculated in $$$, whether from PV, LiFePO4, or gasoline. It makes a convenient "currency" for consideration of efficiency options.
So caI would compare the purchase price of a replacement refrigerator with purchase price of additional PV panels to power the old, inefficient one.
66 kWh per year is remarkably little in a way that you could survive trough 3 months total darkness of arctic winter on battery power alone.
But we're talking about winter here!
And you're worried about how to keep your milk cold?!
Without knowing your hardware you probably should let the solar charge controllers take care of the battery voltage regulation and set the BMS cutout somewhere above the normal operational range.just to toss this into the discussion... So I was having transient voltage surges that were triggering my inverters HV disconnect. and this was why: I over paneled this year when I commissioned/installed my lithium bank. I did this as I wanted more power in the gloomy months and or winter to keep the battery cells charged as long as possible prior to loss of solar input.
whats happening is that my solar controllers voltage starts surging when the BMS shuts off charge. I tried to taper my charging using the controllers settings to avoid issues but no dice. so one controller#1 shuts off at 54 volts. the next inline #2 shuts off at 54.2 the next at 54.3 and the last one at 54.4 but when the inverter draws a big enough load they all turn back on. amps/watts surge and after about 5 or 6 minutes the bms shuts down charge, but the inverter is still pulling power so the controllers surge above the 54.4 settings and then one after the other shut off due to high voltage settings. when the last one shuts off it sends a millisecond voltage spike to the inverter which then shuts off due to HVD and after a short time at normal voltage turns back on. cycle repeats several times before the sun goes low enough to prevent this. still trying to figure out how to prevent this. damn first world problems!
sorry put this in the wrong discussion, but to answer honestly... I did that, BMS are set to cut off at 3.65 per cell or 54.4 for the pack inverter is set with a HVD of 64 volts so the issue is that the MPPT SCC get wonky when the battery is disconnected. nothing is harmed, it just cycles the BMS & SCC & inverter both off and on.Without knowing your hardware you probably should let the solar charge controllers take care of the battery voltage regulation and set the BMS cutout somewhere above the normal operational range.
