I have a 12 panel system with a Solis Hybrid Inverter and i'm having problems with the data that i'm seeing through Soliscloud.
The system was initially installed in October 2022 and through to December the consumption and 'imported from grid' data appeared to be accurate and roughly tied in with what i was seeing in terms of meter readings.
At some point though, the figures started to be way lower than they should be - or at least what i think they should be.
As an example - here are my figures for March
The Consumption of 730.36 and 489.51 are way lower than they should be and way lower than my meter readings for the same period.
My meter has moved by approx 850 kWh in the same period and i also have the myenergi app which shows 850kWh imported. I believe the 850kWh figure to be more realistic than the 489.51 but it is higher than i would expect and i'm concerned i#m not getting the full (or any) benefit from the panels. Without accurate data from soliscloud i'm finding it difficult to track though.
I haven't reported this to Solis/Ginlong yet (not sure if i even can)
Has anyone seen anything similar to this before?
