We bought a new (to us) RV in the fall. Used it once and then winterized it. It has a solar set up installed.
2x100w flexible panels glued to the roof, a unknown "MPPT" controller and 2 GC2 6v 220ah batteries. A mid winter check showed the system was toast. 10v and 0 amps from the panels and 2 batteries that were badly bulged.
So I need to start from zero. So after a couple of weekends garage sales and estate sales, why yes Dear I would love to go a garage sale instead of fishing, I ended up with mostly two systems.
1. A 280w rigid panel UNK brand, an unknown 40 amp MPPT, a Renogy 2000w inverter, and an unknown 30 amp ATS.
2. 2x 100w rigid Chineseum panels, a Bouge 30 MPPT .
I bought new 2ea Vatrer 100ah Lifepo4 batteries and a Renogy 30 amp DC to DC MPPT charger. I still need fuses, wire, terminals and stuff.
Plan is to put the 280 panel on the roof and use the 100w panels as a ground mount when the RV is shaded.
Questions Panels parallel? 2 controllers? Does the inverter need the ATS?
15 years ago I installed a very basic system 60w panel and a sunsaver 10 amp pwm. That is the limit of my solar skills.
