corn18
Village Idiot
- Sep 9, 2021
- 769
Just in exploration phase. I have a full Victron setup in my 5er that I wish I had in my house. But I don't. House has 200A mains service with a 50A subpanel for the generator hookup. Manual interference switch from mains to genset. The genset is a Westinghouse 9500W/12000W (surge) 240V/50A on natural gas. This works fine but man is it obnoxious when that beast is on. The subpanel includes the heat pump for air conditioning.
I installed an Emporia Vue energy monitoring setup and learned a lot. The interesting part is that my house basically has an idle use of 600W. That's with some lights on and a TV. Unless one of the big loads kicks in, it pretty much draws from 400W to 1200W (if all the fridges are running at once). That seems like something that a battery backup system could handle with aplomb. My 5er could handle that for a long time, maybe forever with the solar.
I am thinking a simple battery backup system could easily handle these loads.
EXCEPT
I want to be able to run the air conditioning. Heat is gas so no problem there. The 3T heat pump draws 6000W on startup (I installed an easy start) and 2000W running. This is the same issue I have with my RV. Easy to handle everything and run forever until you introduce an air conditioner. In winter, the battery backup would be all we need and use the generator to charge the batteries (no solar).
I'm stupid when it comes to residential stuff so what would be a good way to handle this? Primary backup is batteries and if I want to run the aircon I have to start the genset. All of the loads in the subpanel are 120V except the aircon.
Our power outages are 10 per year for 2-6 hours. Worst case was 16 years ago when the remnants of a hurricane came up to Ohio and power was out for 3 days.
EXCEPT
