corn18
Village Idiot
- Sep 9, 2021
- 769
TLDR: Will my 7000W (10,500 surge) generator run my 3 ton heat pump?
I have a 7000W genset with a NEMA L-14-30 connector. This is what the manual says "This receptacle powers 120/240 Volt AC, 60 Hz, single phase
loads requiring up to 7,000 watts of power (7.0 kW) at 29.1 Amps for 240 Volts or two independent 120 Volt loads at 29.1 Amps each. The outlet is protected by a two pole rocker switch circuit breaker."
This connects to my house via a NEMA SS2-50P input that goes to a sub-panel in the house. The subpanel has all 120V stuff on it except the aircon. That is hooked up but the electrician told me to turn it off before I flip the sub-panel over to the generator (not an auto switch).
I got this Emporia Vue energy monitor and it says the 3 ton heat pump draws 2000W sustained. Not sure what the surge is but the max amps on the placard says 18.1A @ 230V. So that is 4,163A. I would think my 7000W (10,500 surge) genset could handle that.
I am afraid to just try it. I could do it right now but don't want to fry the aircon. I feel stupid asking this. Whadya think?
