I have a fellow member on another site with a problem who has the factory solar package on his 2022 KZ Escape 231bh. The solar controller is showing code b001 (cannot see battery) and there is no voltage on the battery side of the solar controller. The manual shows that there should be a 30 amp fuse between the controller and the battery. The only thing I can find is 3 inline dc auto reset breakers. All three of those have continuity and appear to be working. Battery is full and all other 12v is working. I told him that the fuse should be in the Battery + line , and that if there is no battery connected, with the solar panel connected, that the controller may be damaged.. He said this rig set on the lot for weeks without a battery connected before it was sold. The sales guy even showed that the lights were working off the solar without a battery and has been working fine until this past weekend. How can this be ??? All I’ve read says to ensure you hook up the battery first , then you can connect the solar panels -- This is correct??? Any thoughts on his system???
