Sorotec REVO II 5,5Kw / EASUN( AXPERT/POWLAND) IGRID VE II 5,5KW
Hello
I have one of these Sorotec VMII. https://www.soropower.com/7/755.html
See Picture
I have a DIY Lithium Battery Pack with JBD BMS and 4 wire RS 485 connector.
Can i connect it to the Inverter using the Pin out attached? will the Inverter read the Battery?
Hello guys,
can I use this inverter as MPPT only ? To charge Battery which is used mainly for the other inverter, this one should just serve another PV side?
rgds,Daniel
HOW DO WE EARTH THE SOROTEC INVERTER?... do you also earth the casing? or just the grid side earth cable?
