Tulex
Solar Wizard
Built my first battery, took forever to top charge, but it got there. Part of the issue other than it just takes a long time with these little power supplies is that it wasn't staying on CC. So, I took advice from here and installed heavy wires and crimped on eyelets before starting my second battery.
This time, the amps is staying constant and the volts climbed. But, it got to 3.53v on the charger and is staying at 10 amps, but it has stalled there. Batteries are at around 3.360 at the ends where the wire is attached, around 3.353 for the inside batteries. Both the Charger and batteries have stalled for over a day at these numbers. Checked the amps on the leads, they show 10 amps. Checked the busbars and wire connections, all are tight.
