I have a travel trailer that I am installing a new solar system onto. It is pre-wired for solar but only had a 10 watt trickle charging panel on roof, next to a 3-port rooftop connection box. I intend to follow Will's video on wiring the transfer switch so that I can charge my batteries and run appliances with either the 3000 watt inverter on a generator. I have 2 questions:
- Can I continue to use the converter/charger that came with my WFCO Power Center to charge the batteries when connected to a generator, or do I have to purchase and install a separate charger? The one that came with the trailer claims to be a 3 stage charger.
- If I can use the existing charger, will the transfer switch prevent the creation of a damaging circular charging situation, where the batteries keep receiving charge from the charger when using the inverter? I know I worded that clumsily, but I am a beginner. I need to know if I have to make sure I power off the existing charger in the power center whenever I turn on the inverter. Any advice would be appreciated. Thank you.
