Yes,, the bank worked great.
They were in parallel, but I disconnected everything when this happened.
The bank worked fine until I plugged a heavy load into the inverter and got the error beep from both the inverter and charge controller.
I was getting the green signal light on both units,, this morning , one is changing to yellow, and now I've got the low one attached to a fully charged lead acid battery to bring the charge back up and see what happens.
I was able to get all the Valence ops manuals and spec sheets though.
You've been more help though. Thanks
