I purchased the same kit from Amazon and followed the provided diagram to wire my device. However, when I scan, I don't detect anything. The software recognizes the correct port, but fails to load any data. I've attempted using an alternate super seal connector and even directly connected the pin to avoid any mismatches, yet I still receive no data. Changing the A/B connections doesn't seem to have any effect. The only response I get is a "Power Surge from USB" message when I swap the 5V and negative connections. I would greatly appreciate any advice or guidance on this issue!In the drop down where you have a number 4 try replacing that with COM4 You have to type it yourself All caps no spaces.
