Hate to be the bearer of bad news... but Wind power, in general, is awful... for details: see: www.solacity.com/small-wind-turbine-truth/
Basically, the problem is most areas have low wind average speeds near ground level.
I was considering a turbine on my garage roof. Then I got into the gritty details of how much wind there really was here, and realized it wasn't going to provide any real power consistently.Hate to be the bearer of bad news... but Wind power, in general, is awful... for details: see: www.solacity.com/small-wind-turbine-truth/
There are specific locations where you can put a ground mounted wind turbine (under 30 feet even) and generate a decent amount of power. A good example is the beach cliffs at marina California. The wind blows all day. Stick a turbine there and you are set..
But yes, for many people including myself, wind is impractical. Sun is easier to harvest than wind.
And wiring up a wind turbine is dead simple. Just connect charge controller to your battery. You can have multiple solar and wind power sources charging a single battery bank.
What confuses most people is the difference between a solar and wind charge controller. They are totally different, and using a solar charge controller with a wind turbine does not work. Wind turbines are 3 phase alternating current, and a solar panel is DC. Wind turbines need a wind turbine controller with a load dump, usually a resistor for the small ones.
If you want to have solar and wind charging a single battery, just wire it up as you normally would. Positive wire goes to positive, negative wire goes to negative.
