Photos are handy but a description is important. I see in the photos a Renogy SCC, your inverter, and the batteries. I do not know what PV you have, the settings of the Renogy for charging your batteries (is it set for Lithium?), nor much about your loads other than I see some what looks like battery packs for tools hanging on the wall beneath your inverter. It is unclear where they get power from.
One thing that bothers me is your use of red wires from the SCC on both the positive and negative SCC's battery output terminals. This can lead to not knowing if the other end of them is wired with correct polarity. They do not seemed to be wired to your batteries correctly. For series 24vDC they would need to be wired to one battery out positive and the other batteries out negative. The jumper from between battery neg/pos would have no SCC wires to it.
