There are multiple threads on here discussing a 48v/12v converter. About 400w is the biggest I have found(victron}. I am considering leaving the magnum me2812 in place for 12v generated power to the sub panel. I intend to leave 2 206ah batteries in place for a bank of power for the sub. My sub carries the refrigerator, microwave, the lighting, and the wall plugs. The sub has a 30amp 120v two pole breaker. I am looking at the Victron 48/10000/140-100/100-120v inverter/charger. It produces 8000 watts at 25C. That is the same as my Onan generator. The Onan has a two pole 35amp breaker, but the tag clearly states that is produces 66 amps of 120v. The main panel doesn't have any two pole breakers except the mains. That means shore power is coming in 240 volt and being used as 120 volt. That is why I will be going with that particular Victron unit.
