Jared,
A little more background...my (3) Lifepower batteries - a year or so old- have gone from fulling charging to 100% from the EG4-3000 when purchased to a 1% gradual reduction in maximum charge per week (99% max for a week, then 98% for a week, etc) to now a 2% reduction in max charge per day. I found I'm able to get it back to 100% SOC by taking the loads off the EG4-3000 and charging with the SS 48V charger. This results in the SOC almost going immediately to 100%. That then restarts the cycle of loosing 2% max SOC everyday after till I do the charger routine again.
Regarding you comment on either the LL or Lifepower being suited for remote application. Below is an excerpt from a document Signature Solar sent me regarding how to fix the SOC problem. It mirrors what has been said already on this thread about the 14 days of 80% DOD, etc to fix incorrect SOC readings. It also goes on to say this routine should be done every month. (I'm not sure many design their system for 80% DOD every day, so to me that means the monthly routine is for most all if not all)
"We also recommend performing a Deep Cycle when the system is first set up and when a new battery is
added to the system. It is also recommended to do this once a month; however, if they are discharged to
80% DOD every day, this is not needed."
A battery that requires doing a monthly 80% DOD routine is not what I'd say is suitable for a remote unoccupied application.
Asking my question another way...does the LL battery require the 80% DOD cycling every month ? More direct, does it maintain 100% SOC maximum recharge capability without any intervention or maintenance routines ?
