I use Groundmount but that works for me.Which method would you choose to mount panels?
I could use the extra and secure space of the container for other stuff as well, but I also wouldn’t be upset about a large carport type structure.
@SamG340 that first one looks awesome!
Interesting.Yes very cool, but lots of metal work to make that happen , and I wouldn't like the look of it when it gets windy
My plan is to mount panels almost flat on the top, and almost vertical on the side , using the strength of the container as the make structure
Two different angles, one favours summer production, the other favours winter.
Two arrays wired in parallel, or using two separate MPPTs
Yes great , using every last inch of space possible to maximize production , so long as they don't shade each otherInteresting.
When I used a triangle calculator I saw if I did roughly a 35 degree mount that would equate to a roughly 8:12 pitch
So with the panels if I two 2 portrait rows that’s a flat length of roughly 12.8ft.
At 35 degree tilt I could run them to be flush on the roof with the back side of the container (similar to your sketch) and about 6ft of gained height to the top of container at the panel peak, and then have roughly a 2ft overhang on the front wall of the container and the panels would end roughly 1 foot below the roof line.
But your sketch could also help bridge the winter/summer gap with pre angled strings for each too
I’m in northern AZ. My latitude is 34 degrees hence my 35 degree reference. Most online calculators said for a non adjusting array that I should strive for 30-35 degree angle for my location@GOO5E where abouts are you in the world ? There are calculators online that will tell you the perfect angles for summer & winter production
(if you're into that kind of thing ! )
gray miserable raining Britain
Here ground mount under 7' dont need building permits, just electrical. But if you attach it at all to a container its not considered a ground mount anymoreWhat region are you?
Up here we get snow- ground mount all the way, or vertical on building wall. Snow never accumulates…
If you are in Florida and can do a ‘carport’ with adequate wind resistance then, ya- no annoyance with panels covered up.
Can still be worth backing it up next to a container as a wind breakHere ground mount under 7' dont need building permits, just electrical. But if you attach it at all to a container its not considered a ground mount anymore
Just make sure to consider your usage. If you are selling back to the grid that is a different optimal angle then being completely off-grid. A steeper angle like 30-40 will give your more consistent year-round production where the 28.8 will maximize total production.Arizona I bet you get good solar production , I don't suppose getting the angles perfect matters like it does here in gray miserable raining Britain ?
Az, USA
44° in winter
14° in summer
Solar Panel Tilt Angle Calculator - Footprint Hero
Calculate the best tilt angle for your solar panels based on your location (address, city, or zip code) with our free solar panel tilt angle calculator.footprinthero.com
Solar panels on almost any angle will still make , you're just playing an efficiency game
