Higher voltage hybrid ?
Externet
Mideast U.S.A.
Hello.
Is there in the market that you know of, any hybrid inverter that will take about 500VDC input from a roof string of panels; and work with 48VDC lead-acid battery bank; outputting ~6KW split phase 240VAC/60Hz with or without grid presence ?
Hello.
i believe sol ark makes one about that size. if not the eg4 18kpv is 12kw of power and will for sure work. but also the 6000xp might work for what you are wanting. just depends on how you intend to use it.
if you intend on feeding back to the grid the 6000xp wont do that but otherwise it is a great unit from what i hear and will do everything else
Hello.
Sol-ark 12k,15k
EG4 18pv
