Hi,
Fact: I need to perform firmware update to the Huawei optimizer SUN2000-450-P.
In order to do so, as far as I understood, I have to install the Huawei inverter SUN2000-2KTL-6KTL-L1 which the upgrade process is managed from.
I'm planning to use the inverter only for optimizer firmware update so I don't need a battery, and I cannot buy one because the inverter requires Huawei batteries which are out of my budget.
My questions are:
- If there is no battery, the Inverter will power up? if so, what is it power source if not the battery? the grid?
- Solar system which composed of solar panel-> SUN2000-450-P optimizer -> SUN2000-2KTL-6KTL-L1 Inverter: should work properly?
- Does the SUN2000-(2KTL-6KTL)-L1 is able to connect to non-Huawei low capacity batteries?
Info:
https://royalamerica.com/wp-content/uploads/2021/03/SUN2000-2KTL-6KTL-L1-User-Manual.pdf
Please help!
Thanks.
My questions are:
Info:
System Power-On - SUN2000-(2KTL-6KTL)-L1 User Manual - Huawei
Version:V200R001.This document describes the SUN2000-(2KTL-6KTL)-L1 in terms of its installation, electrical connection, commissioning, maintenance, and troubleshooting.
support.huawei.com
Thanks.
