TurbineTester
- Apr 1, 2021
- 143
I have 6 EG4 batteries in the 6 slot EG4 battery rack, no bus bar swapping, no communication setup and two EG4 inverters. There is no PV input, no AC input and No ac output set up yet. I only have the batteries mounted in the rack, and the inverters mounted on the wall with cable run from batteries to the inverters. Upon power up they booted fine and both showed full battery charge, even though the batteries themselves only show 2 LEDs lit for charge status. I only powererd up the inverters to test them out before proceeding onto other wiring. After about 5 minutes the #2 inverter, which is not connected at all to the #1 inverter save through the common 48V battery connection, started beeping with the number 61 on the screen. It showed that the batteries were at a low state of charge, even though the other battery showed full charge. I tested the battery voltage at the inverter connection (with the inverter off) and it was at 52.3VDC. I could not find the error code in the manual, so i came here. All other threads about this issue seem to relate to some communication setup between inverters or batteries. But my error persists even with only 1 of the batteries powered up, and only one of the inverters powered on. So i'm not sure what i need to do from here other than contact Signature Solar, which i'll have to wait till Monday. Any suggestions on what i can do to fix it between now and Monday?
