Hope someone can help.
I'm struggling to get my head around nodered as , at least to me, its very unintuitive. Of course it may very well be that I'm a bit thick but in any event could someone please give me an example graphical flow and the node properties to do the following.
Flow 1:
Do this every minute from 12.30AM until 04.19AM.
Read the charger source priority and output source priority on inverter_1
If the output source priority is not Solar/Utility/Battery then set it to Solar/Utility/Battery
if the charger source priority is not Solar and utility simultaneously then set it to Solar and utility simultaneously
Flow 2:
Do this every minute from 04:20AM until 12.29AM.
If the output source priority is not Solar/Battery/Utility then set it to Solar/Battery/Utility
if the charger source priority is not Solar Only then set it to Solar Only
Flow 1:
Flow 2:
