codymccomber
- Jan 9, 2020
- 4
Hello All,
I currently live in the desert completely off grid with a 2KW solar system on my Fifth Wheel roof and about 10KWH of battery storage and 5KVA Inverter all DIY. The system is fantastic, although I will be expanding to ground solar now that I have a permanent place to stay.
I will be purchasing a Tesla vehicle(Cybertruck!!) in the future and I am working on getting my charging system setup for it. I know I need a significant amount of solar...luckily I have 20 bare acres and live in a sunny climate so there will be plenty of sun and space for the panels. My goal is to charge the vehicle without batteries in-between the solar and the inverter. I would love to charge DC direct, but all my research so far shows that that is not an option at this time outside of super chargers.
I am trying to understand the setup and limitations.
If I go PV to inverter to vehicle, or PV to MPPT to inverter to vehicle:
Will the car start and stop charging as clouds pass over or with the connection need to be reset manually in the vehicle every time the output of the panels dip below the set charge rate in the car? Is this a viable setup to charging a Tesla without battery storage as an intermediary?
(I understand this is over simplified and that fuses, breakers and properly sized equipment is necessary)
Thanks for your help!
