Tomthumb62
Solar Wizard
- Sep 25, 2022
- 1,871
Our Victron 24 volt 1200 VA Phoenix inverter fires up a fan when under significant load. No one would describe that fan as near-silent. Morningstar does not use fans.
What OP is describing isn’t anything I’d consider a “significant load”.
Our Victron Phoenix 12/1200 inverter only fires up the fan when the fridge comes on, which is about 800W for 2-6 seconds, then the fridge drops down to 60-80W and the Victron’s fan turns off.
If OP sizes their inverter properly, they will never hear the fan power on. Those Morningstar inverters are expensive for that fanless luxury.
A Victron 12/500 or 24/500 would probably be more than enough for OP. If not, then the /800 model would do the trick. Most likely the fan would never come on, since there are no surge loads in this setup.
Even when we were camping in 85-95F heat (inside of trailer would reach in excess of 105-110F), our Victron inverter would still rarely run the fan and no longer than 15-60 seconds. 99.9% of the rest of the time, the fan only ran for 2-3 seconds as the fridge powered up. Since modern fridges tend to run for longer periods of time, the number of cycles per day is pretty low, leading to the startup surge fan blowing for 2-3s cycles to be few per day.
