hugemoth
Seems like a good deal over the Victron unit. I have one on order.
Ok thanks for the clarification one of the reviews mentioned he had to make his own lead.
- Amazon says it comes with 500 Amp TBD-SmartShunt with instructions, two red cables with fuses, a black cable with fuse, and two M5 mounting screws.
Wow super cloney look of a Victron smartshunt. ...
For my use case that doesn't matter, I just want a cheap accurate shunt.The VE.Direct on the TBD SmartShunt and the Victron SmartShunt are RS322-TTL interfaces.
The data output from the TBD SmartShunt is entirely different than the Victron SmartShunt.
In other words any software designed to parse/decode the Victron SmartShunt output will not be able to parse/decode then TBD SmartShunt output. I have both and have futzed with both but have not completely figured out the data from the TBD SmartShunt.
The TBD Smartshunt is garbage. Of the 5 or 6 I've seen my brother use in the last 6 months only one still works. Most of the time it seems to come from disconnecting the power and reconnecting it. One time the app reported incorrect voltage. Sure enough, disconnected the power and it was dead when he reconnected it. Buyer beware!Wow super cloney look of a Victron smartshunt. But apparently doesn't work via ve.direct for integration with a Cerbo GX or other Venus os device. Also doesn't come with power lead? Seems like a cheap/easy inclusion.
I have been using mine for a year and a half now with no problem.The TBD Smartshunt is garbage.
