2 separate systems work great, as long as you keep them separate !
When you talk AC , you talk about frequency, 60hz in the states.
This frequency
MUST be matched. so there will be a "master" that gives the "go", and the "slave" that follows.
Try to imagine... 2 batteries, 2 inverters, master / slave, all seem good.
- situation 1: slave battery is empty first, it stops. battery get charged, wakes up as slave and... all ok
- situation 2: master battery is empty first, it stops. ->
slave will become master as there is no one to listen to.
battery gets recharged, the "old master" wakes up, assuming its still master....
2 captains on 1 ship, 60hz, a small out of phase will provide
magic smoke....
you absolutely don't want this.
As for many things, there is a workaround, you are lucky that you have Victron.
Victron has a "pass through" of 100A
You don't place them in parallel, but use one victron AC-out as the AC-in ("grid") for the next.
This normally will
NOT work, as most inverter are limited in pass through to their own capacity.
normal inverter: 2 x 5 kw inverter, max output = 5 kw.
For victron: 2 x 5 kw = 10 kw, 5kw from the inverter and 5kw from pass through.
This way there is no master or slave.
there is "grid" (provided by the other) or no grid.
I haven't tried this, but there isnt a reason why it should not work.
Looping them, both AC out to the AC in (grid)... that doesn't feel like a workable solution
Obviously.you need to configure the Victron that it doesn't use the "grid" (AC provided by the other Victron)
Workaround, that works
ONLY with inverters that have a high pass through.
Deye SUN12K-SG01LP1 is one of the few others that I found that have high pass through.
