HighTechLab
AKA Dexter - CTO of Current Connected, LLC
- Sep 23, 2019
- 1,710
did I hear someone mention pushing the limits???You will, eventually. lol
I was looking at the Big Battery Rhino for this reason, I have wall space but not much floor space so the less than 5 inch depth is intriguing. Price point is not as good though compared to this EG4 or the Ruixu wall mount unitsI really like that the connections have been moved to the top, and the width is a little smaller. My area is pretty cramped, so I really appreciate any extra room I can find. I'm curious that they left the heater in.
I'm glad that EG4 is paying close attention to code compliance. I spent months trying to find a setup that would pass local inspection. At least I won't have to worry about the EG4 products.
I really have to agree with this, and hope we see a change to this in the manual. Space is often a problem, and forcing us to spread things out for no real reason related to safety or performance does a disservice to everyone but bureaucrats and insurance adjusters looking for any reason to deny a claim. Please don't feed either of those two beasts.So you purposefully made the manual requirement harder than what was necessary just to appease some AHJs?
That seems dumb. The manual should be the actual requirements. If an AHJ says 2 ft and you see 6.75 inches in the manual, you have more room to argue for 12 inches.
In other words, you shouldn't pander to the AHJ authority escalation tactics. Put what the product will do in the manual.
Mike C.
Here in Ontario, the rule is 1m spacing between ESS units/batteries, OR as per manufacture's installation instructions. So even here, we'd have to space it out 12" then, even though it was tested closer together and is safe that way.I really have to agree with this, and hope we see a change to this in the manual. Space is often a problem, and forcing us to spread things out for no real reason related to safety or performance does a disservice to everyone but the bureaucrats.
Can these be controlled/monitored through the EG4 Comms Hub? For those of us with a rack already in place - this would be an easy way to continue to add storage in a smaller footprint, but I don't want to have to replace those I already have.
I really have to agree with this, and hope we see a change to this in the manual. Space is often a problem and forcing us to spread things out for no real reason related to safety or performance does a disservice to everyone but bureaucrats and insurance adjusters looking for any reason to deny a claim. Please don't feed either of those two beasts.
Where do you see that?I see now that they require 7" spacing.
See post #68Where do you see that?
Sorry, I got confused by your reference to back-to-back spacing (while maybe querying front to back spacing)See post #68
I should have said. "A minimum of 7" spacing "
Is there a requirement of minimum open distance in front of the batteries?
I live in Minnesota so NEC 2023 code. My potential power shead is 6' X 6'. I am hoping to place them back to back. (I see now that they require 7" spacing. )
Why can't you mount them back-to-back and still have 36" clearance in front of both of them? I mean, _HOW_ you are going to do that is an open question, but the only official spec EG4 has posted is 7" side clearance...With the lack of response. I will assume that in my circumstance that I need to have a minimum of 36" of clearance in front of the unit. So no back to back install.
If it will not need maintenance (in place), no maintenance requirements apply.The shed is 72" square for the out side dimensions. I figure, by the time I insulate it. I will loose 6 more inches. Which brings me down to 66" wall width. It's actually one of those aluminum sheds that the railroad uses at crossings for their electrical equipment. All aluminum and critter proof. Very happy with it's build. And I couldn't build something like it for the same price.
My goal is to mount around 60k worth of batteries and 1 or 2 inverters in it. Plus the extras. I can start my own thread relating to my system when I'm really serious. But the question still remains.
What is the minimum clearance requirement for the front face?
As far as I understand, I'm not a electrician. A breaker panel needs a minimum width of 30" (or panel width, which ever is greater) and 36" in front. Does a ESS follow this also???
Probably depends if you are talking code or just reasonable functionality. In order to get UL 9540 certification (as I understand it), the mfr must pick some combination of spacing, connections, capacity, wiring, etc, etc, etc, and then submit for the certification. They don't get to ask UL "Hey, what's the minimum spacing?", they have to get (or fail) certification for 12" or 7" or 2" side to side (front to back or back to back isn't specified). I suppose if they wanted to they could resubmit for 5" spacing if they failed 2" spacing (or whatever), but that's a lot of money for very little (sales) gain. No-one is looking at two different mfrs and choosing an ESS based on side to side spacing requirements (even if your AHJ doesn't require 12 feet just to be obnoxious and they don't care what the UL9540 requires).Does a ESS follow this also???
Another thought, if you insulate it you may need to manage heat rejection in warm weather.The shed is 72" square for the out side dimensions. I figure, by the time I insulate it. I will loose 6 more inches. Which brings me down to 66" wall width. It's actually one of those aluminum sheds that the railroad uses at crossings for their electrical equipment. All aluminum and critter proof. Very happy with it's build. And I couldn't build something like it for the same price.
