Relatively small gauge wire daisy chaining positive and negative.
Might be around sufficient for current of one battery, not for max capability of all in parallel. So for extended hours, not higher amps.
Tapped in the middle as g00se observed, so two of those wires in parallel.
If tapping bat+ in middle, suggest bat- from the two ends.
