Of course they do! Set 'em free!Ordered Dec 28, shipped Jan 4, delivered today (Jan 8). Ironic that both of my Voltronic inverters have been on their best behavior since I ordered. It's like they know....
No it keeps data till your reset it or it runs out of storage space. I just was wondering if it had a total power ever produced somewhere in the beta or something.I think it only keeps the last 12 months unless you download and save it externally.
Which models?I'll most likely be ordering 2 HYPs
HYP4850U80-HWhich models?
That's 110 only? have to pair up for 220?HYP4850U80-H
Correct.That's 110 only? have to pair up for 220?
Think I'll wait around for the stackable version of the asf48100u200. Hopefully, they get it right.HYP4850U80-H
I'm 99.99% certain it's the same inverter, SRNE is the OEM.I have a SungoldPower 10kw (SPH10K48SP) Inverter which is I believe an SRNE clone.
When I enable BMS input and connect the BMS, Configuration Item# 12 (Battery overdischarge voltage) gets set to zero.
This value specifies when the inverter output will be switched off should battery voltage fall below the setting .
Sungoldpower keeps kicking the can down the road when I ask about this. (i.e is this a firmware flaw)
Just curious, does the SRNE inverter have an equivalent setting and does it exhibit the same issue when the BMS is connected.
Have you gotten it instead?Ordered Dec 28, shipped Jan 4, delivered today (Jan 8). Ironic that both of my Voltronic inverters have been on their best behavior since I ordered. It's like they know....
I don't use BMS communications with the inverter, only Solar Assistant. USER ftw.
I assume it gets set to 0 because SOC takes over.
I have the latest firmware from SRNE (haven't flashed it) if you want it.
The displays look different. How much is the same? Even if they use the same boards, I wonder about one brand using cheaper parts to populate the boards. I've seen other consumer based products where one brand uses higher quality parts to populate their boards vs others. Has anyone investigated this?I have a SungoldPower 10kw (SPH10K48SP) Inverter which is I believe an SRNE clone.
