You need a bigger battery pack ?View attachment 190578
Tested to see if it would trip. Itll just switch back to grid. Very very impressive
You pulled ~225a off a 35% battery and the inverter didn’t mind?View attachment 190578
Sigh, tell me why I could see the numbers in the orange screenshot changing (like they do when on the SRNE site and it auto scrolls to the next specs)Wonder if this is the 12KW version? not available for the US yet...
Kinda makes me want to consider a transformer again....
Who was looking for a 3 phase inverter recently?
800VOC... Most could run 16S strings...
View attachment 1907508kw 10kw 12kw Storage Inverter
ASF series is a new type of solar energy storage inverter control inverter integrating solar energy storage & utility charging and energy storage, AC sine wave output.www.srnesolar.com
Bms didn't shut down. Inverter went into that grid over protection switch. mode. forget the name. I'm up over 30kwh nowYou need a bigger battery pack ?
YesYou pulled ~225a off a 35% battery and the inverter didn’t mind?
That’s awesome!Bms didn't shut down. Inverter went into that grid over protection switch. mode. forget the name.
Yes
Same, not/never enabled and didn't know it existed til pointed out by @42OhmsPAIt has the option to sell excess loads to the grid, I've never turned it on. I've had zero issues with it disabled. I am not aware of any external CT.
How does the anti backflow work if there are no ct's?It has the option to sell excess loads to the grid, I've never turned it on. I've had zero issues with it disabled. I am not aware of any external CT.
It most likely does not. Don't think any of us have tested this, howeverHow does the anti backflow work if there are no ct's?
If I remember right all of your packs are made up of different parts right? So wouldn't the soc vary from that?I'm throwing in the towel on getting SOC to match....
Just going to keep running it...
That's pretty much where I am as well this SOC stuff is kinda nebulous...I'm throwing in the towel on getting SOC to match....
2 packs are 230ah cellsIf I remember right all of your packs are made up of different parts right? So wouldn't the soc vary from that?
I run 3 280's and one battery comprised of 304's. One of the 280's is half 280K and the other half 280N. Top 2 batteries are 280N's.If I remember right all of your packs are made up of different parts right? So wouldn't the soc vary from that?
I'm definitely using one big main busbar on my next expansion.I do run all cables to busbars down the sides of the cabinet all the same length. I run a nickel plated busbar down each side that I plated myself comprised 1/4" x 1.25" copper.
