Old_Skewler
Here is the (12) panel design I am working with, two parallel strings of (6) panels in series each. Panels to be Canadian Solar HiKu6 400W @ 108 cells connected to a Victron 250/70 MPPT & 48V battery bank with 15 kWh capacity.
I have a few lingering questions that I could use some help of feedback with:
1. MC4 cable\ing and MC4 splitters seems to be cheaper than running (2) sets of cables down the house to a combiner box but I believe the combiner box is worth the extra price in terms of safety (fuses) and functionality (disconnects). Is this correct? Or is it overkill for this small installation? I ask this because most of the combiner boxes I've seen seem to be for more than 4 strings... And If I were to use splitters on the roof I would have to only run (1) set of cables down the roof instead of (2) sets.
2. Assuming I go with the combiner box on the side of the house, how should I run the (2) sets of MC4 cables along the roof/side of the house? I suspect the answer is in a conduit. If so, should I be able to run the (4) cables inside one conduit on the roof? Or should I expect to run two conduits on the roof?
Thanks in advance!
Thanks in advance!
