Goin'Solar
This weekend I installed my new 18kpv system with 2 PowerPro batteries. Got everything wired up, went through the (poorly described) start-up process -turned on the batteries, set the battery comms protocol to RS485, P01-EG4, switched on the Battery breakers on the 18k and the system sprang to life... sorta.
The first issue was no communication with battery. Shut down everything in reverse order and checked the communication protocol. It was correct as above. Did some googling and found a post where someone said try other comms... That didn't work so I switched back to RS485, P01-EG4. Started up and shut down a couple times- never went beyond turning on the battery breaker and now the inverter won't even turn on. Batteries show 55% state of charge.
Going to call customer service to see if I can get any help, but wanted to ask for any help or ideas here while I wait for them to open.
