Happened to run across something new in the way of solar panels as I was researching possible buys at Ebay on 200w panels to add to my second array. There are kits that allow you to bolt together 100w panels either as a 2 in 1 for a 200w panel or 4 in 1 for a 400w panel. Yesterday I offered to buy a 4 in 1 that was listed at $278.99 for $265.00 and the offer was accepted. Should be interesting how it (they) work out adding to my array. The present setup is all 200w panels in a 2S2P arrangement. Since the voltage of the 100w when in parallel equals the voltage of a 200w and the added amperage of two 100w in parallel equals one 200w the math all works out. I likely will run 2 of the new 100w in parallel and than in series with 2-200w panels and than in parallel with the other 2-200w + 2-100w. Sorta blows up the simple array of XSYP designation.
Heck, I am not sure how I should refer to it other than as total array wattage of 1200w at Voc of 65v and 22a.
If anyone else is interested the panels are listed at: https://www.ebay.com/itm/404204938041?hash=item5e1c7de339:g:4MkAAOSwCOJkEW28&autorefresh=true
