Solarfun4jim
Solar seduced :-)
Just goes to show how many people are stripping these threads no matter how careful they try to be !8 is too high. The 7 I'm using I think is too high as well - I believe I've stripped one of mine using 7.
I have to agree with @Hedges.The batteries that Iam building are going in my boat. Since this will be a marine environment I purchased zinc plated studs, I was thinking of purchasing yellow zinc nuts, maybe yellow zinc nylocks if I can find them and lock washers, and using noalox or ox guard, what do you guys think?
Thanks Hedges.My suggestion of JB weld was as repair of stripped threads, an alternative to tapping oversize. If the materials are clean, it will never come out.
The others have various degree of locking strength. Purpose being to keep stud from turning when tightening nut, likely any is good enough once it cures.
Im going to epoxy studs in right from new. An epoxied threaded connection, especially into a soft material is far stronger than the threaded connection. 0 worries about damage at 8nm.My suggestion of JB weld was as repair of stripped threads, an alternative to tapping oversize. If the materials are clean, it will never come out.
Remember the 8 Nm is the anti torsion of the terminal top. I think epoxy is a good idea. I just think other readers still need to be careful that they don't twist the terminal top off the connection to the innards of the battery. Four to five Nm is the recommended torque of the nuts to get good connection of buss bars and lugs to terminal top.0 worries about damage at 8nm.
And someone mistook 8nm for proper torque, stripped the thread out.Remember the 8 Nm is the anti torsion of the terminal top. I think epoxy is a good idea. I just think other readers still need to be careful that they don't twist the terminal top off the connection to the innards of the battery. Four to five Nm is the recommended torque of the nuts to get good connection of buss bars and lugs to terminal top.
Is it stronger? I wouldn't count on that. But maybe true. Have an explanation?Im going to epoxy studs in right from new. An epoxied threaded connection, especially into a soft material is far stronger than the threaded connection. 0 worries about damage at 8nm.
When Im rinsing them I am planning to hold the cell upside down and use a squeeze bottle with a straw.Alumabrite does look effective. It does contain hydroflouric and sulfuric acid so I should wear gloves and use it outside with plenty of ventilation. That way i could rinse them with plenty of water as recommended. My studs are already permatexed into to terminals so I hope that won't be a problem. I am already planning on using aluminum buss bars so I can easily just dip them in the Alumabrite also.
If you double nut the top of the stud or have an internal hex you can apply the counter force and have reduced risk of twisting the terminal.Remember the 8 Nm is the anti torsion of the terminal top. I think epoxy is a good idea. I just think other readers still need to be careful that they don't twist the terminal top off the connection to the innards of the battery. Four to five Nm is the recommended torque of the nuts to get good connection of buss bars and lugs to terminal top.
I can only offer a wild ass guess that the epoxy would increase the effective surface area in contact with the soft aluminum. I don't know how that compares with Permatex Red. Either one has to be better than nothing because the studs were loose when just inserted in the terminal tops.Is it stronger? I wouldn't count on that. But maybe true. Have an explanation?
That takes care of twisting.If you double nut the top of the stud or have an internal hex you can apply the counter force and have reduced risk of twisting the terminal.
Yes, both good strategies. So far no one has reported twisting off the terminal tops possibly because the threads strip first and torsion on the terminal tops is probably reduced by the leverage of a buss bar attached to an adjacent terminal.If you double nut the top of the stud or have an internal hex you can apply the counter force and have reduced risk of twisting the terminal.
Threads dont engage the entire land area of the opposing thread (the major diameter of the male thread is smaller than the major diameter of the female threads). filling the gaps in the threads and at the bottom of the blind hole/end of stud provides more surface area as well as preventing threads from deforming into space that is now occupied by epoxy.Is it stronger? I wouldn't count on that. But maybe true. Have an explanation?
