thealaskan
- Mar 3, 2020
- 129
Picked up some CSUN 305W solar panels, and an eco worthy combiner box that I new I was going to have to re wire a bit. I'm doing a 2S, 2P 4 panel configuration was going to rewire in the box so all 4 panels plugged into it, and into a MPP LV2424.
What I found is all wiring and polarity's are different than the markings on the items in the box, which is a 2 wire output surge protected grounded unit, and I don't understand.
I do know in Europe that Blue is designated as the +, in a 2 wire grounded circuit but when I look at this, they have the+ male plugs on Blue wire into the - designated pieces, they have red wires on the - female MC4 plugs with the fuses on the - side of the circuit? C Sun panels are clearly marked uncolored +.- , with the male MC4 connector on+ witch is correct.
I guess my question would be:
1. Are the fuses supposed to be on the + or - side of the circuit?
2. Not familiar with the surge protector, is it polarity sensitive?
3. Are the color codes wrong and this came out of a backdoor shop?
4. I was going to use the 10A fuse as one per panel, with the C Sun panels 8.5A max power current, did I order the wrong unit for my application?
5. What about polarity into the LV2424?
6. Should I just re wire the whole thing with the known color codes to be uniform, because this to me looks like some one could get hurt?
The price wasn't that expensive, for all the pieces and parts I would think to get it all here and put together I did good.
