dmkjr
I've read the changelogs, "1. Add N-G relay control function. The setting 42 to disable, the relay will short input and output neutral always as following “C” block. The setting 42 is disable, the relay will close on ground or floating side when inverter work in Battery mode as following “A and B” block. The default setting is disable."
Could someone give us the benefit of this firmware? Will this stop or attempt to stop the light flicker? Was that the problem that this was targeting? While I build my own system, I'll stick with the network engineering and leave the electrical stuff to your crazies.
