robbob2112
Doing more research, mosty harmless
the umm "smart" charger has a 10A option according to the photo that i put up for you...
just looked, i even see 18A
Won't know until you get it I guess. It needs to have a SLA setting to be useful. Your batteries have a max charge current of 11 amps each. But, charging at less than that will make them last longer. A current of 10 amps across both should be split to about 5 amps each and work best.
The reason for the SLA setting is so the batteries are not over current or over voltage at any point during the charge. SLA batteries are particularly sensitive to either of those compared to other lead acid batteries. What happens if you exceed either is the acid boils and the plates get a hard coating that makes them loose capacity.
A regular setting for a car battery would be bad.
Watch for the sides to bulge as a sign of troubles.
