OK, glad you're open to it.
PV panels have specified Voc open circuit voltage, Isc short circuit current, Vmp maximum power point voltage, Imp maximum power point current.
Those measurements are taken with panel at 25C room temperature, flashed briefly with one standard sun, 1000W/m^2.
In other words, not allowing the panel to warm up in the sun, because current will be reduced when it gets warm and leaks current internally.
What you measured was Voc (zero current) and Isc (zero volts). Under some sun and temperature conditions.
If loaded down to Vmp (about 15% lower voltage than Voc), it would produce Imp (about 15% less than Isc.)
W = Vmp x Imp.
You never get Voc and Isc at the same time, so multiplying them together does not give a power number that is achievable.
A "12V" PV panel might be about 22Voc, 18Vmp. There are testers for PV output (similar to battery testers the auto store uses.)
If you had 6V batteries, three in series would be around 18Vmp, might be a suitable load.
Or, apply a resistive load. I used some electric radiators, two in parallel to test a "24V" 165W PV panel.
Or if you have an MPPT charge controller, and you connect it to a battery that needs recharging (or battery plus load), then you could measure PV panel voltage and current at maximum power point, Vmp & Imp.
