The copper idea is great, copper conducts electricity well and easy to work with and affordable in small quantities and the only draw back is that copper has a tendency to corrode in damp and salty air environments especially when copper is connected to a different metal. Conductive electrical grease helps keeep corrosion down to a minimum. While stainless steel is also conductive, I hear that is not nearly as good at conducting as copper, iron, lead etc..Oh. Ok. Make your own. A piece of 1/2" copper pipe squashed flat and drilled out. That way you can make them exactly the length you need. Or a piece of flat stock steel/stainless.
If you're on a budget you can use 1/2" copper pipe flattened out and drilled. You can even get creative with shrink tubing if you want. I did some prelim numbers and I think 1/2" 'L' ('L' is thick walled and carries more amps than 'M' pipe) pipe carries well over 100 amps with no problems.Sorry. Should have been more clear. This would be a battery terminal to terminal flat bar for series connection of lifepo4 cells.
For point of reference. My bank is a 16S by 36P. Max charging is 60 or 80 amps, I forget which off hand. What I did when I built it was to use #24 wire as fusing between each pos battery terminal to the continuous neg rail of the next parallel 3.6v leg. Each 4S battery in the 48v system is ~12v (4S by 36P). Where all the pos #24 wires are tied to the pos outgoing rail I used 1/2 inch 'L' pipe. So essentially you have 36 times #24 wire as your current capacity base.Do we (me) really need to worry to much about having high amp connections? I currently have (5) 8s banks. Only growing from there. I charge at 60 amps .2C or roughly 12 amps at each bank (or .66 amps per cell). My nominal/continuous draw (in summer) is currently about 10 amps (.033c). Even if I quadrupled that draw (.165c) for startup of any appliances/AC its still very minimal per paralleled bank. So I would think just a solid copper #8 wire to each terminal would be more than enough wouldn't it? Or would there be a resistance issue even at 2 inches. Again, just trying to see the need for such heavy connections....
