timselectric
- Feb 5, 2022
- 19,120
WTF, is what I thought when I seen it. lolOMG. I was thinking WTF???
I like the way you put it better.
Previous comments about the terminals were that the breaker and or screen didn't allow the cable to run vertically. With that being the only complaint about the terminals, why would you make it worse?Easy to access might also mean easy to access... with something conductive ;·)
Maybe UL requirements, looks a bit like how a breaker terminal is recessed into a cavity in the plastic case.Hey, maybe no one complained, but they leaned a metal case or something across the terminals themselves at the warehouse... I don't know... some reason they must have had :·)
No it’s not a requirement.Maybe UL requirements, looks a bit like how a breaker terminal is recessed into a cavity in the plastic case.
When you redesign a product, you should improve on the things that your customers complain about.
I want to know who complained that the terminals were too easy to access? View attachment 112157View attachment 112158
Terminal connections most likely a manufacturing cost saving measure, but Dual On-board Fire Arrestors should be a great selling point. Many other improvements (if in released product) will also make some feel it is a product they can safely install in their home. With more flexibility with different inverters available. Wait and see is all we can do.Clearly, it's designed for a short takeoff to side mounted busbars with a heavier cable run... I suspect there's a plastic cover similar to the gyll/lifepower4. After all those other improvements, I find it interesting that the only thing you have to talk about is a relatively minor design feature.
Looks like a pain, with the small cable. Would be worse with a larger cable.Clearly, it's designed for a short takeoff to side mounted busbars with a heavier cable run...
The first priority should be usability.I find it interesting that the only thing you have to talk about is a relatively minor design feature.
This is the production model. It's available, now.Terminal connections most likely a manufacturing cost saving measure, but Dual On-board Fire Arrestors should be a great selling point. Many other improvements (if in released product) will also make some feel it is a product they can safely install in their home. With more flexibility with different inverters available. Wait and see is all we can do.
An "L" shaped bus bar, would work. But shorting to the folding handle would be a concern. This bus bar would need a protective cover.Makes me wonder if EG4 will come out with a custom "joiner" to connect the battery terminals to the rack busbars.
I notice the Chint breaker got left in the dust.
