new jkbms firmware
cali-clim
new firmware jkbms avec logiciel
  • JKBMS-PBXX-V14.17.rar
Change list
-V14.17 Upgrade logs
1.Fixed a bug where parameters were lost after BMS restart. The bug is caused by a logical error in the parameter entered by the user.
2.Change the default configuration parameters to LPF to improve security.
2.Optimized JKBMS Modbus protocol, added RCV RFV register support. The protocol must use the PC software version V2.5.0。
3.Fixed the Bug that the hardware version may be incorrect in the device information.
4.Add battery low temperature alarm to dry triggers.
-@2024-01-09 by JKBMS
Change list
Finally, a changelog.
Reminds me of when I was on the factory project team installing a new piece of production control software. I found a bug but the software companies project leader refused to admit it was a bug and instead called it 'An undocumented software feature'.
Hi-
Can you report the changelog for the new 5.17 firmware available from
Does it fix the issue where the SOC is 100% before the pack is done charging?
