yodamota
I wonder if the ballast makes the panels run cooler in these bucket arrangements?
Yes, not in DIRECT sunlight for 50 years as stated. Paint helps a lot.It does look like glass reinforced HDPE. It probably will last a really long time. They are also shaded by the panels.
If you say so........The powerfields are 550 lb when filled to the brim with sand or gravel with a wind load rating of 120mph.
Glad to hear that. I have some Powerfields on order ?I have those buckets 6 rows of seven panels. Eight buckets per row. Each bucket has 85 pounds of ballast. I’m up on a hill that is very windy, I have been getting more than more than 50 mph winds. They don’t budge.
Only one row, would take some serious real estate if one wanted a 25Kw array.They're Heavier.
And block some of the wind flowing under.
Which are both helpful.
I need a 53 degree option. i don't think ballasted will be an option.
Where I am in Texas, anything you put INTO the ground is going to shift something awful from the ground cracking apart. In the summer I can have 6" wide cracks form in the ground that are 4' or more deep! My yard looks like The Grand Canyon is trying to form some years.It's just not that much more expensive to drop 4x4 posts in with a wood frame. I dunno, once you start filling tubs with rocks the annoyance goes up, and you still have to deal with the wiring. The only reason I can think of to use this type of mount was for something temporary, but then you have to do something with the ballast, and ...
How much was it per watt/hour? delivery cost?SunBallast.com sparked my interest
I honestly did not dig that deep into the math. My turning point was pricing the iron ridge system. Once I locally was able to price the 2" galvanized pipe for completion of project.....I was left shocked with the price of just materials. SunBallast system cut my mount cost down by more than 50%. No brainer for me....and an easy install. They were located in Clearwater, FL....no delivery. Had a company drive down with a trailer and deliver to my property.How much was it per watt/hour? delivery cost?
I would rather take my chances with the plastic buckets than a pole/post in the ground.
I received an engineering report with my 16 panel mount, this is the force just at ground level on each pole.
Not even discussing uplift.......
Whelp....how about I just post.....Whelp... how about...
How much solar do you have?
and
About how much was the total cost of the mounting?
It's been happening more and more here with drought conditions in central Texas every year. Don't move here. We have no water.You put a house on this? 6" is a really big crack. I've never seen anything like that in my life, but if I lived where the ground cracked apart randomly with 6" wide cracks 4 feet deep, I'm pretty sure I would sell the place and move. No way in hell I'd build on it. Florida sinkholes come to mind as well. A wise man builds his house upon the rock.
I agree, the flat angle is a problem.
Not for us Floridians!! Flat is our heaviest months for electric usage!I agree, the flat angle is a problem.
Given that the ballast mount is at an even shallower angle, it's subject to both less wind and lifting loads. With 550# of balast in it, you can take that 120mph rating to the bank. Again, this is just engineering. Sometimes intuition is wrong.
10-15 degrees off is not going to cost you much. It just isn't. Now this was not super scientific, I'll admit, but I put two rows of panels in my back yard propped on block at different angles last summer for a week at a time, just to get a rough optimization before I put in my ground mount. I really was having trouble measuring the difference between the ones at 30 deg and the ones at 10 deg (~Optimal). After rocking, and facing this way and that, my best guess was it might cost me ~5% worst case, maybe, if I noticed anything at all. Now the farther off the equator you get the steeper those bad angles get, but at least here I'd just shoot for the middle and run with it. Optimal here is ~7/30/54.Not for us Floridians!! Flat is our heaviest months for electric usage!
Have you not seen the Powerfield Energy ballasted ground mounts?What do you think? I like them. Think about how easy an off-grid system is if you threw this on the ground in your backyard. Excited to see more of these come to market:
View attachment 189928View attachment 189929View attachment 189930View attachment 189931View attachment 189932
