Nonsense. Let me try to debunk some of those points.
The majority of the energy from the sun is in the visible spectrum and solar panels are tuned to this. Here is a graphic:
As you can see, there is very little energy in the UV (and IR) range and solar cells are tuned for this. There is a whole bunch of physics about this (band gaps, tying incoming photon energies to specific energy gaps in the material etc. which is also where Perovskites come in, but I'm not going there in this post). Suffice to say that claiming that solar cells only work in the IR is rubbish.
Current solar panels are around 20% efficient. So? Car engines aren't much better. Efficiency doesn't really matter if cost/Watt makes it efficient to use them to generate energy.
The heat production thing was discussed in another post, so I won't repeat. The impact is negligible. However that other person also writes:
Like wise with CO2. its only 400PPM which is 0.04% of the atmospheric gas composition.
which ignores the effects of a greenhouse gas in those concentrations, by somehow concluding that it's only a small amount so it couldn't possibly have an impact. Chlorine Pentafluoride is dangerous (IDHL value) at 1.7 ppm - barely anything, so can't possibly have an impact, right?
During the Cretaceous Hot Greenhouse roughly 92 million years ago we had CO2 concentrations of over 1000ppm. There is a reason why industrial greenhouses use carbon dioxide supplementation - which is great for plants, but not so much for humans.
By Megha Poudel and Bruce Dunn. Learn about carbon dioxide, its concentration in relation to plants, supplementation, the effect of supplemental CO2 on different growing factors, sources of carbon dioxide and control and distribution of CO2.
extension.okstate.edu
Finally: define 'green energy'. In my opinion, it, or renewable energy is energy derived from sources that are replenished at a higher rate than they are consumed, and where the total emissions of the plant (including building and decommissioning) is lower than the equivalent other methods of generation using fossil fuels. I also add nuclear to the list of green energy.
