jasonojordan
Hello all new to this forum. Little back information on my system here before we dive into my question
Inverter: Solark 12kw
Panels: 20x 410w JKM410M-72HL-V
Battery: 100ah 48v Tess Electric
System: Grid Tied with garage panel acting as a critical loads panel
With that out of the way my issue is with my 100ah Tess Electric Lifepo4 48v battery. I feel like it has never really been setup right from the get go and have not had good luck working with the seller of the battery to get it working the way I want it to. I was under the illusion when I purchased it that it would work in the closed loop communication with the Solark. So far this has not been the case.
I am looking to find out if there is a list of known BMS out there that do work in the closed loop communication system with Solark so that I could potentially purchase and install one on my current battery in replacement of the current BMS.
Bonus points if anyone can help me get my current BMS communicating with the Solark. Right now it is working off a voltage only basis and have had issues with running the battery down to low and the BMS on the battery kicking in and creating havoc. I think that issue may be rectified with some new values from the battery seller but it is too early to tell.
Anyways this post has gotten long enough. Thanks in advanced and see you around!
Jason
*EDIT* See attached PDF I created with the pinouts that worked for me to get this brand of battery working with the solark in closed loop. Have some things to verify but by all accounts appears to be working correctly. See page4 with where things started to get successful.
Jason
