jasonojordan
That is weird.
Did you try all the modes of BMS in the Sol-Ark not just 0?
On the solark I have not tired anything other than 00
That is weird.
pylontech comes in 2 flavors :On the solark I have not tired anything other than 00
old : 0
and new, i believe 12, but for the life of me, can find the ref document anymore
yeah, i mean no harm in trying..So perhaps try other addresses rather then 00 on the solark side?
good luck..Sounds good. Let me know if you find that sheet to help me narrow down the amount of trial and guess I end up doing.
good luck..
after changing modes it usually takes up to 45-60 seconds for the comm to come "alive"
that is what i always used, but my experience is limited to the seplos bms, pylontech and jakiper , eu modelsCan this be done without going through the whole ordeal of rebooting the bms and the inverter? Just activate the lithium battery in the settings on the solark and change the number and wait a couple minutes?
that would be the actual procedure, and once you get any comms, i'd run through that regardless.Sounds good. I will give it a try. I had been just been following the procedure in the SOK video and it makes for a lengthy trial and error process with all the reboots and such.
Worth a Shot. Once you change it then it will work or won’t. Shouldn’t need any reboots.So perhaps try other addresses rather then 00 on the solark side?
how did you fare ?Thanks guys I will give this a shot sometime this week
how did you fare ?
the last screen is exactly what i am seeing ( of course filled with the correct data)I took time to go out and play again today with it raining and not missing out on any solar generation.
For battery I have option of 00-06 I can not go up to 12.
Only difference I saw was when set to 06 the screen looks like this instead of what I'm accustom to seeing. It showed this screen however work or without the battery communication cable connected to the solark and still faulted our for bms comm failure
so there must be something going on, just not filling in the correct data yet
Correct screen just no info.I took time to go out and play again today with it raining and not missing out on any solar generation.
