zanydroid
Solar Wizard
What about the new 3 wire feeder you put in last year? Can you retrofit or replace that?
TBH that should have been done to modern code (4 wire, since it was way past the code change), then you would have had more options to address this…
You might also consider various isolation transformers and aggressive use of GFCI breakers to mitigate the risk.
This grounding scheme is getting farther away from what I think is advisable to figure out on your own as a non grounding expert / trying to crowdsource an answer.
