S Davis
Solar Addict
- Sep 25, 2021
- 678
I have a ton of lugs just no 90 degree, I am going to need 8 for the eight class T fuses. I will check them out.I am a huge fan of Selterm. Can get from Amazon
2 ga 200c silicone wire was in this order.
but that unprotected steel is near a protected “bus bar” of the class t, correct? Maybe your concern would be for the other end of the class t?Better BUT I had a heart palpation when I saw all that Open Unprotected Steel. A flash in my mind of what would happen if a piece of metal bridges that connect to (+) and the bracket etc... 1 oopsie Flash = 1 Bad Day.
1) I would at minimum put heat shrink to cover the busbar from Fuse to Terminal. Also I would shorten the M8 Bolt so not so much thread is exposed. "Murphy Temptation".
2) Your Angle Bracket ! PLEASE TRIM THAT DOWN ! get rid of excess and really make sure it is all "soft edged" so nothing sharp...
Another Murphy Temptation".
Never EVER provide temptations / Invitations for Murphy to come and apply his laws onto you. Straight from the Lesson Learned pile of Crisis Management, Rule 1 being Prevent the crisis in the first place !
I like the selterm, has the UL stamped right on.I’d rather bend selterm lugs into 90 vs alibaba units.
Agreed some how I’ve built a war chest of them at 4awg and 2/0 in 3/8, 5/16 and 1/4. Kinda ready for what my build will need.I like the selterm, has the UL stamped right on.
That is the quality I have been buying from DelCity electrical supply, thanks.Or if you want to be really safe with right angle lugs: https://www.digikey.com/en/products...IAuoQA4AuUIAyuwE4BLAHYBzEAF9xhAExkQmAK4jszcUA
Thanks that is about half of what I have been finding them for. On a off chance I am having my local Allphase check on pricing, usually I can find stuff cheaper on line though even having an account with them for over 20 years.These might be good - https://remybattery.com/cable-conne...erminals/magna-lug-heavy-duty-connectors.html
I see Signature Solar sells some Magnalug connectors
The ones i usually buy can only be installed with a hydraulic press tool, trying to use a hammer tool just doesn’t work well, you don’t get consistent results. The ones they sell at Lowe’s and Home Depot are usually garbage. You want to make sure they are cast lugs.Just remember there is huge differences in "lugs". A $2 lug is likely not going to be the same as a $8 lug. For the same lug size, if they provide weight that would be a good indication of how much copper was used since I've seen some really thin ones compared to the named brand ones from Panduit but you likely won't see weight listed for the super cheap ones.
I dunno if I mentioned this before in THIS thread. I have been using SelTerm Tinned lugs for years and never had any issues at all. The "Closed" type of terminal is best because there is no exposed copper. Selterm lugs can be bought direct from them (Fast shipping, well priced) or from any Reputable electronics suppliers like DigiKey (bit of markup but really quick delivery).The ones i usually buy can only be installed with a hydraulic press tool, trying to use a hammer tool just doesn’t work well, you don’t get consistent results. The ones they sell at Lowe’s and Home Depot are usually garbage. You want to make sure they are cast lugs.
The gotcha with the Chinese Hydraulic Crimpers if they are Metric & that it's so good when doing AWG.
