Surplusdoctor
- Nov 14, 2019
- 51
I just bought 8 cells of 80AH lifepo4 batteries to build a 24v battery, and I need the terminal connectors. Where can I buy them all ready made?
Will has blueprints with links to Amazon. https://www.mobile-solarpower.com/wire-and-connectors.htmlI just bought 8 cells of 80AH lifepo4 batteries to build a 24v battery, and I need the terminal connectors. Where can I buy them all ready made?
But not for just the connectorsWill has blueprints with links to Amazon. https://www.mobile-solarpower.com/wire-and-connectors.html
do you want battery to battery or battery to inverter? they're both thereBut not for just the connectors
Many have been on a quest for those. No one seems to have them, except when sold as part of a battery kit. I suppose it's because every battery connector dimensions are different, and they would need to either be custom made for the application, or stock a lot of what may never be used. Not cost effective either way.The first is a smaller 400 watt, but I need the battery to battery terminal connectors. Who sells them?
^^ like I said Click the blueprint and scroll downThe first is a smaller 400 watt, but I need the battery to battery terminal connectors. Who sells them?
You didn't say thatI can make these, I'm looking for the flat bar style
Okay I will just build my own, thank you for all your help,Many have been on a quest for those. No one seems to have them, except when sold as part of a battery kit. I suppose it's because every battery connector dimensions are different, and they would need to either be custom made for the application, or stock a lot of what may never be used. Not cost effective either way.
smartazz........In order to find something it's important to know what that something is called. Google "battery busbar connectors"
