scarpenter002
- Sep 22, 2019
- 5
I am in the process of installing my system on my fifth wheel trailer. I have fished the cables down from the roof to the basement and about to start the assembly process. Based on reading and watching other, I had originally planned to install all the components in my basement proper, which is heated, but watch a lot of recent installs, I have a seen a pattern of individuals installing it forward of the basement, in the compartment with the batteries. I currently have a lead-acid deep cycle, but will be upgrading to multiple AGMs. Will have various breakers, fuses, cutoff switches, battery monitor shunt, solar controller w/ Bluetooth attachment, cabling, etc... Eventually I will add an inverter/charger (Leaning toward the Victron Multiplus). I live in the south, and have NO plans to stay north for the winter.
So is it ok to have the entire system in the battery compartment or should I install in the basement? Why or why not?
Thanks in advance for your input.
Scott in Southeast Texas
